Ford 9" Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2008, 02:18 AM
66Moostang's Avatar
Ford 9" Rear End
I am going to be hopping up an old 66 Mustang and with the engine I plan on putting, a friend said he would definitely recommend a Ford 9" rear end. I wish I could agree but I am new to this kind of stuff. I know about engines and what-not but I honestly don't know much at all about the Ford 9" rear end. Could someone maybe direct me to a website that could enlighten me or share any information I could look into for 450+ HP?
Old 05-17-2008, 02:48 AM
SSedan64's Avatar
Here's 1 link if your looking for donors to find a 9". Or do a search on this forum for 9" Info.
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
Old 05-17-2008, 09:53 AM
leldai73's Avatar
Its just metal,you're the boss
heres are some brief instruction on to install gears in your axle.
http://www.ridgenet.net/~biesiade/gearinstal.html
and this is an OK overview of a cheap, but very slick, rear disk break set up. you can use junk yard parts where they buy new.
http://www.mustangandfords.com/howto...ion/index.html
Old 05-17-2008, 10:24 AM
I suggest this site ...
http://www.kevinstang.com/Ninecase.htm
As for the 9 inch VS 8 inch agruement ... remember that when Ford built the early Hi-Performance Mustangs with the better horsepower ... 271 HP / 289 ci ... Ford installed the 9 inch rear.
Whenever the horsepower went up ... in went the 9 inch.
Old 05-17-2008, 06:06 PM
Notorious's Avatar
Hot rodder, not street rodder!
I believe what you're asking is if you need a 9". With 450 HP, (although torque is what breaks things and would be a more relevant number) the short answer is yes. Your 8" could possibly be beefed up to take it in a light car like the Mustang, depending. But... the 9" would be more cost effective in the long run. 9" housings that will bolt in were used in '67 through '70 Mustangs that came with the larger engines. I'm not sure if the housings from '71 through '73 Mustangs got wider or remained the same. Also, '57 through '59 Ford 9" housings are actually 1" narrower than the Mustang ones and would go in with little problem.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 01:53 PM
9" conversion for 48 ford rear end big mal Transmission - Rearend 1 08-23-2005 10:47 PM
ford 9" rear end stangfiend Engine 4 10-10-2004 04:30 PM
ford 9" rear beetle9 Transmission - Rearend 12 10-27-2002 06:57 AM
