Ford 9" Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2002, 09:27 AM
Post Ford 9" Rear End
Are there any identifying markings on a Ford rear end housing which would tell me if the center section is 9" or 9 3/8"?
The (donated) unit I have, has disc brakes and coil spring mounts (not a Versailles).
The previous owner thinks it was in a 1973 Lincoln with a 460 engine, but I'd like to know for sure before I put any time into it.
I don't think they make after market parts for the 9 3/8" section.
Old 05-31-2002, 10:46 AM
New Member
Post
9 3/8 was not made past 1972 and no 9 3/8 had disc brakes on rear. good luck...
Old 05-31-2002, 11:18 AM
Post
Thanks for information, you rule
Old 06-03-2002, 05:12 PM
WoodsEdge's Avatar
Post
You didn't say what you were putting this rear in, but 70's Lincoln had the widest rear for 9". I think they were 60" flange to flange. May be good idea to check what clearance you will have. Early Mustangs were only 52", to give you a reference.
Old 06-04-2002, 02:40 AM
New Member
Post
hypermart.net/9inch -- This site has tag codes, sizes and ratios for 9" rears
Old 06-07-2002, 10:46 PM
New Member
Cool
Here is another good site re Ford 9 inch rears, good info on what they cane out of, how to id etc
http://dfwmotorsport.com/Fairlane/9inchrearends.htm
Cheers
Sandman
Old 06-08-2002, 07:12 PM
Post
9 3/8--- never heard of it, any info?
