Ford 9" Rear End Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 04:22 PM
New Member
I have a Ford 9" rear end under my 56 Chevy. It came out of an 84 Ford F150 1/2 ton. Would this make it a 31 spline?
Old 07-01-2006, 04:43 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
moving to The correct forum
Old 07-01-2006, 06:19 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Are you sure of it's origins? That is an extremely wide rear end for a Tri-5. Six inches wider I think.
No it could be a 28 spline. There is only one way to know.
Old 07-03-2006, 09:19 AM
Mustangsaly's Avatar
http://www.kevinstang.com/Ninecase.htm
theres other sites too.............
Mustangsaly
Old 07-03-2006, 11:39 AM
xntrik's Avatar
If the metal tag is still on the chunk bolt, you can have the numbers decoded and that will tell.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
1946 ford Truck Rear End HELP Jim1926 Transmission - Rearend 1 11-29-2005 02:50 PM
9" conversion for 48 ford rear end big mal Transmission - Rearend 1 08-23-2005 09:47 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
