on a ford 9 in rear end what rotors and calipers to use for disc brakes. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2010, 10:23 AM
I have a ford 9 inch rear end with small bearings and would like to install some disc brakes without buying someones kit. What rotors and calipers can i use for this installation . I don't need emergency brakes either. Thanks for all your help. 1931 graham rod. Fred
Old 10-31-2010, 01:11 PM
Onefunponcho's Avatar
lincolns
Mid to late 70's lincolns had disk brake nine inches..... not sure on the bearing size though sorry
Old 10-31-2010, 01:40 PM
Irelands child's Avatar
The mid '70's Lincolns with discs were the Versailles. While it can be a good choice, finding one with all of the parts plus in good shape is getting tough as Ford has discontinued replacement pieces.
As an idea, Speedway offers a weld on bracket/kit
http://www.speedwaymotors.com/ProductSummary.aspx?free_text|10/31/2010%203:35:36%20PM=9%22+disc+brakes&deptId=0
and;
http://www.speedwaymotors.com/US-Bra...Kit,26350.html
I know you said you don't want a kit, but sometimes ya just gotta see what's out there and often, you'll find it ends up cheaper
Dave W
Need Calipers for 8.8 rotors 2000jack Suspension - Brakes - Steering 4 03-26-2008 09:20 AM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 06:01 PM
9 inch ford home made disc brakes zonk Suspension - Brakes - Steering 6 06-02-2006 12:31 PM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
