FORD 9" Ring & Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 03:13 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I just removed my center section from the housing and in the inspection I am finding some rust on 3 or 4 of the ring gear teeth.
Can I clean this up with ???? and pack it with Molly grease and run it slow up on stands for a while?
Is there anything else I can do to save this gear set, or am I looking at alternative?
Old 06-02-2010, 03:29 PM
That rear axle must have set for a while. I have seen this a lot where the axle sets and the oil settles in the bottom and runs off of the teeth that are above the oil level line. Moisture then causes the uncovered teeth to rust. Unless you're running some serious horsepower I wouldn't worry about it. I would however worry about the bearings for if there is rust on the teeth then there is more than most likely rust on the bearings. If so replace the bearings assemble the rear axle run it for a month or so and change the fluid. You could spend a little time removing the rust that is on the teeth with a wire wheel but don't get carried away with it. The rust that is on the gears will remove itself when ran.
Old 06-02-2010, 05:19 PM
ericnova72's Avatar
More for Less Racer
If that is all the rust there is, cover things up so you don't blow junk into the spider gears or bearings and clean the teeth off with a wire wheel. If you just run it the gears will knock the rust off after a bit, but iron oxide (rust) is as gritty as sandpaper, you don't want it dispersed in the oil to the bearings.
Old 06-02-2010, 05:35 PM
65ELCMO's Avatar
just wire brush it, wash it out with some brake kleen, put some grease on the gears and install it. Use some average oil and drain it after 500/1000 miles and put in some good oil.
Don't worry, be happy
Old 06-02-2010, 06:37 PM
If steel wool will clean it with no pitting, you're good. If the rust is caked on and leaves pits it may make noise. No harm in cleaning it up and trying it out as if it works, you're good. If not, what have you lost? Time?
Old 06-02-2010, 07:42 PM
big gear head's Avatar
High Performance Rear Ends
I agree with KMatch, clean it up with steel wool, a wire brush or anything and then give it a try. If the gears have rust on them then there is a chance that some of the bearings might also have rust on them. I've seen this a lot.
Old 06-02-2010, 10:00 PM
solidaxel's Avatar
Well that sounds like just what I will do!!!!!
Thanks
Like was said the only thing I have invested is a little time and a gasket and some 90W
Old 06-04-2010, 11:32 PM
solidaxel's Avatar
Well that is complete, but before I install the rear end I checked the back lash and it had .032 .
The last one I set up was a 62 Chevy and if I remember it was to have between .006 and .009 of backlash, is the Ford the same?
Old 06-05-2010, 11:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You'd like to see the backlash between 0.008"- 0.012". More is often seen on used diffs, but 0.032" is excessive, regardless.
Old 06-05-2010, 11:48 AM
The pinion might be moving slightly when you are checking the backlash. Be sure that the pinion can not move at all when doing this. Even if the pinion only moves a few thousandths this will throw off the backlash reading by quite a bit. You need to have .008 to .012 backlash.
Old 06-05-2010, 11:58 AM
solidaxel's Avatar
Thanks for the information!
I set it at .008 rechecked it twice and put some Mystic grease on the ring gear and installed it.
When I get the driveshaft installed I will run it on jack stands for 15-20 min, with fresh 90W and listen to it.
I won't be able to tell until I get a load on it but that is all I have invested so far
Old 06-07-2010, 04:08 PM
cranky1's Avatar
Just stuck
I've run plenty of rusty gears with no problem and some ended up having pits. So long at they still have plenty of base metal they will be fine and if pitted....the pits will only hold oil. Ran one set that looked so bad that I had my doubts but even those ran quiet and for a long time in a street car.
Reverse Rotation Ring & pinion Arrowhead Transmission - Rearend 11 12-24-2007 05:20 PM
Ring & Pinion Tooth Contact Pattern GM 10-Bolt leejoy Transmission - Rearend 52 12-15-2006 06:26 PM
Ring & Pinion Setup - GM 10-Bolt Help leejoy Transmission - Rearend 3 11-21-2006 07:02 PM
Ford C7AW E 9" Rebuild Help and Disc Brake Questions Mustangsaly Transmission - Rearend 12 11-06-2005 12:44 AM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
