ford 9 third member bearing removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2013, 01:34 PM
trying to remove the the small pinion bearing inside my ford 9 third member. looks like there is some kind of snap ring that needs to be removed before bearing can be removed. is this so or does the bearing and ring all come out all in one?
Old 01-01-2013, 02:44 PM
to clairify its the small back support bearing in the case
big gear head's Avatar
High Performance Rear Ends
Drive it all out together. Save the retainer. Some installation kits come with a new retainer and some don't. You might have to use it again.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-10-2013)
Old 01-01-2013, 02:45 PM
ok... ill see what i can do
Cam bearing removal tips? truckboy61 Engine 20 10-06-2010 11:08 PM
Rear Whell bearing removal 355Nova Transmission - Rearend 30 05-29-2010 07:28 PM
ford 9 bearing help supercharged sbc Transmission - Rearend 4 07-27-2008 08:44 PM
rear bearing removal goshawks00 Transmission - Rearend 7 11-05-2007 08:23 AM
30's Ford steering column bearing? Kruzin Karl Suspension - Brakes - Steering 2 11-27-2006 03:39 PM
