Ford 9" vs Dana vs Chevy 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2011, 09:46 PM
wakisashi06's Avatar
Ive got a 383 4 bolt main 71 lt1 heads with a fully built th350 in an 91 s10. blew the stock rear end any suggestions.
Old 05-11-2011, 01:24 AM
327NUT's Avatar
I would use the 9", lighter, very strong, you can get parts for it anywhere but best of all it has a 3rd member....aka pumpkin, chunk etc. that you can pull out and change gears ratios in an hour or so...if you're good. Cain't do'er with the other two.
Old 05-11-2011, 02:54 AM
not as good as a 9 but a verry easy cheap swap is the explorer 8.8 97-2000
lsd and available 343-410 ratios.
31 spline and strong as a ox
Old 05-11-2011, 05:03 AM
cal1320's Avatar
Use the 8.8 Exploder. 60'' wide. Disc brakes are standard on later models. Get some C clip eliminators and call it good.
Old 05-12-2011, 10:16 PM
ok thanks everyone
Old 05-13-2011, 06:11 AM
Dana makes tons of the Ford 9" for Ford
Trees
Ford 9" axles in a 10 bolt Chevy rearend. RP40 Transmission - Rearend 2 12-14-2008 12:26 PM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
9" ford with chevy bolt pattern retired 56 Transmission - Rearend 4 02-17-2008 10:44 AM
14 10.5" bolt chevy VS 9" ford Trav Transmission - Rearend 4 09-01-2003 07:49 PM
9" Ford or 12 bolt Chevy HotRodS10 Transmission - Rearend 23 01-13-2003 05:52 PM
