My buddy has installed a 9" ford rear end out of a 79 Lincoln Versailles. He doesn't want to use the calipers that was stock because of the park brake in the caliper. Does anyone know of a caliper that could be bolted in it's place without the park brake mech. I forgot to tell you it's in a 48 Chev. Thanks Jesse
I don't understand this either. The VERSAILLE axle asm. is desirable because of everything being self contained. The caliper mounting brackets are unique in that they attach to the actual wheel bearing retainers instead of the axle tube ends. To modify this asm. would be expensive to accept any other type of caliper.
Ok, here is what is going on. The way he mounted the caliprers on the axel for clearence purposes was to roll the calipers around to the front side of the axel and the put the left on the right and left on right. This leaves the pull for the parking brake pulling from the back instead of the front. As low as the car is, its the only way he could do it without the calipers hitting the frame. He will probaly use a drive shaft set up for parking. The problem now is that when pressure is applied to the piston the parking brake rotates out and the piston doesn't apply the pads. He has looked around but can't find a caliper that will fit. I hope this makes sense. Your help and comments are appreciated. Jesse
He is going to have to abandon the VERSAILLE rear (the cost of converting it is prohibitive plus wasteful) and decide exactly what type of disc assembly is going to work on the car. It might be FORD...Might be GM. Then he is going to have to choose the rear asm. that goes with the brake asm. and mount that.
If he wants to retain FORD components, he is going to have to decide which system will work (MARK VII-EXPLORER-CROWN) and maybe have the tubes and ends modified to fit his chassis.
I wrote a complete thread here on FORD rear disc conversion. Use the search feature to see if you can find it. It will show the popular systems in use.
Does any one know of a source for emer. brake cables for a Versaille rear end?? Those brakes will not work correctly with out the emer. brake hooked up. Mine were cut when the rear was removed.
Jack
Usually, the VERSAILLES cables ends are used and spliced (with connectors) to the host cars system. The little balls are crimped onto the cable with a special tool.
Kultulz, DUH, why have I been trying to make something so simple into something difficult. In my mind I thought I had to have new cables and then adapt them to my emer. brake handle. Thanks for the reality check. Also thanks for the blow-up.
Jack
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
