Ford 9'' yoke seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 08:38 AM
fat40's Avatar
Ford 9'' yoke seal
I have a ford 9' in my 40 Ford Coupe,it is leaking a oil at the yoke. I took the drive shaft off to replace the seal and found the nut that holds the yoke on loose. What I need to know is what is the right way to tighten this nut, and how do I replace the seal? Thank you.
Fat 40
Old 02-16-2008, 07:25 AM
31 five window
Last journal entry: Moving along with patch panels.
My first ? would be why did the nut come loose.I would remove the yoke and front cover and inspect the bearings before Just replacing the seal and retorqing the nut.
Old 02-17-2008, 12:21 PM
68NovaSS's Avatar
Wiki Edits: 9
Check for bearing issues like speedy said. If they appear worn or damaged, replace them. If you dn't change anything, some will reuse the crush sleeve, I prefer using shim packs and solid spacers in the 9". Either way, tighten the pinion nut until you have 15 inch/pounds or rotational torque for used bearings, 25 for new bearings, that's without the R/P installed. That should result in the correct torque on the pinion nut. If using a new crush sleeve, be prepared for a workout with the pumpkin in the car. I broke a quality 24' breaker bar and shattered two sockets, use hardened sockets, Craftsman frowns when you bring one back that's been abused like that, he he, I once used a hydraulic jack to crush the sleeve on a Suburban, very backyard and can be tough on your teeth. Once the sleeve has started to crush, go slowly to achieve the rotational torque. If you're not wanting to disassemble the differential, I'd torque the nut to a factory spec if you can find it, it will be high, probably in the area of 125 to 150 ft/lbs? Then check for excessive binding or resistance. Someone here may have a better procedure for that.
Replace the seal while the pinion yoke is out of course. Just pry out the old, I like to rim the new seal with sealer and tap it into place with a block of wood so as not to damage it, keep it square in the opening.
Once I got the sleeve to crush, I backed off the pinion nut, I locktite it and go for the final. I've never had one come loose and done many in my day.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
th350 rear seal leak billg_69gmc Transmission - Rearend 6 08-08-2004 02:55 PM
