-   -   Ford alternaor not charging (http://www.hotrodders.com/forum/ford-alternaor-not-charging-225942.html)
mustang 671 11-10-2012 02:30 PM
hi all . i have done a something silly .
all my wiring hadnt been cleaned up and now that i have got my engine running i decided to clean up all the wiring and also tape it all up and clip to the chassis and tidy it all . during this some of the wiring needed to be sorted out and untangled. so i did that. and then got in a pickle and had to refer to the owners manual of my 1967 ford mustang and find which wires were to go to the regulator . it now doesnt charge !! doh .
does anyone know and easy way to fix this without undoing hours of work ? ie is there a simple diagram i can follow from the alternaor to the "seperate"regulator to get it charging . its not the connections as i have checked all of them and all the fuses are ok so its all looped in and should be charging.
what a numpty :(
mustang 671 11-11-2012 10:19 AM
had a fiddle around today and still cant get it charging. any electrical guru's out there to guide me on whats wrong ?
66GMC 11-11-2012 10:31 AM
The wiring colors may vary from year-to-year, but that Ford charging system used the same external regulator for many years. Some of the early versions used contact points inside, but the replacement electronic versions are completely "backward compatable".
I just posted this in a thread a few days ago:
http://www.hotrodders.com/forum/hei-...ml#post1608152
The wiring diagram there is from a 1979 F150 ... but it's very typical.
Joe G 11-11-2012 12:14 PM
1 Attachment(s)
Here's a link to the factory wiring diagram for a '67 Mustang. This diagram shows the ignition and starting circuits as well as the charging system. In the attached diagram, I simplified the original to show only the charging system.
Hope this helps....:thumbup:
Joe
mustang 671 11-11-2012 02:00 PM
thanks for the links. and they are alot easier to follow in the link you sent. funny though as i have the diagram in the workshop manual the same and thought i followed it . well looks like im going back and checking which goes where.
thanks for your help guys
