Ford alternaor not charging - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2012, 02:30 PM
mustang 671's Avatar
hi all . i have done a something silly .
all my wiring hadnt been cleaned up and now that i have got my engine running i decided to clean up all the wiring and also tape it all up and clip to the chassis and tidy it all . during this some of the wiring needed to be sorted out and untangled. so i did that. and then got in a pickle and had to refer to the owners manual of my 1967 ford mustang and find which wires were to go to the regulator . it now doesnt charge !! doh .
does anyone know and easy way to fix this without undoing hours of work ? ie is there a simple diagram i can follow from the alternaor to the "seperate"regulator to get it charging . its not the connections as i have checked all of them and all the fuses are ok so its all looped in and should be charging.
what a numpty
Old 11-11-2012, 10:19 AM
had a fiddle around today and still cant get it charging. any electrical guru's out there to guide me on whats wrong ?
Old 11-11-2012, 10:31 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
The wiring colors may vary from year-to-year, but that Ford charging system used the same external regulator for many years. Some of the early versions used contact points inside, but the replacement electronic versions are completely "backward compatable".
I just posted this in a thread a few days ago:
HEI Distributor and Alternator, ford 460
The wiring diagram there is from a 1979 F150 ... but it's very typical.
Old 11-11-2012, 12:14 PM
Joe G's Avatar
Here's a link to the factory wiring diagram for a '67 Mustang. This diagram shows the ignition and starting circuits as well as the charging system. In the attached diagram, I simplified the original to show only the charging system.
Hope this helps....
Joe
Old 11-11-2012, 02:00 PM
thanks for the links. and they are alot easier to follow in the link you sent. funny though as i have the diagram in the workshop manual the same and thought i followed it . well looks like im going back and checking which goes where.
thanks for your help guys
Alternator charging, then not charging corvette77 Electrical 7 07-23-2011 07:29 AM
1989 Ford 150 charging system irratic dieterschmied Electrical 1 10-05-2009 10:40 PM
'70 Ford charging problem C-10 Electrical 1 08-07-2008 09:50 AM
charging system not charging i want to learn Electrical 6 02-24-2008 06:53 PM
2001 Ford Van Charging System NAIRB Electrical 4 06-09-2005 06:01 PM
