ford aod - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2007, 07:07 PM
ford aod
hi i have an aod in my 1989 f-150 (2) wheel truck thats shot. i also have a1989 bronco (fullsize) 4x4 with an aod. my question is obviouse, can i switch tail sections to use the 4x4 tranny in the 2 wheel drive truck. and if so, what is the convex prism shape in the center of my 4x4 tranny pan for. thanks, wayne
Old 01-10-2007, 07:22 PM
Ford AOD
No Wayne you won't be able to swap units,different output shafts on these units,unless you are capable of dismantling the units to swap shafts.
The 4x4 unit has a deep pan,different filter,no big deal if your swapping stuff around. Of course you can't use a 4x4 filter with a 2 wheel drive pan.
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 09:45 PM
Ford AOD id numbers help wheel-7 Transmission - Rearend 3 12-01-2004 03:49 PM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 11:09 AM
AOD Ford tranny (lost fourth gear) shagginwagonvic Transmission - Rearend 8 10-13-2002 02:48 PM
AOD ford transmission melbishop Transmission - Rearend 9 04-11-2002 01:29 AM
