ford AOD/POWER LEVEL - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2011, 08:49 AM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
HAD AN 87 MERK ,RUSSIAN ran the lite..Tran's was rebuilt by an good tranny man. Now in my 57 wagon/ 69 351w 2v ,motor. 650 holleyalum. manifold elelbrock.How will aod hold up to the basic stock 351? T/v valve setting is good . also 4:11 rear ANY TRAN PEOPLE ?
Old 07-14-2011, 03:09 PM
JeffB's Avatar
Depends on the year of the AOD, 88-93's are best for a build.To really learn about the AOD check out:www.clickclickracing.com there is plenty to read before you start asking questions.AOD's prior to '88 can be modified and improved with some beefing up and swapping to the '88-93 valve body.With your 4:11 rear gears you should install a Trans-Go Hi-Rev Kit in the governor for proper shifting.
Old 07-14-2011, 03:27 PM
trans go Hi rev kit
can this Hi-Rev kit be i nsalled in the car?
Old 07-15-2011, 03:08 AM
JeffB's Avatar
Yes it can,click on this link:http://www.clickclickracing.com/foru...ght=#post59753 then scroll down to post #5 and click on that link,it explains how and has lots of pictures.
Pan level VS stick level th350 sooper Transmission - Rearend 5 07-03-2010 04:50 PM
power steering on 55 ford airboy Suspension - Brakes - Steering 2 01-23-2008 09:48 AM
Ford 300 six needs more power ivansolorio Engine 5 06-08-2007 11:36 AM
331" sbc power level? 327NUT Engine 5 07-22-2006 02:45 PM
Ford 5.0 oil level problems xntrik Engine 7 06-30-2006 12:51 PM
