Ford AOD problems... Slipping Not Shifting Right - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 07:09 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
Hey Scoob! over here!!
Hey,
Friend of mine named something like Scoobydoo is going to sign up in a few minutes and has questions about his AOD slipping intermittently. It's in a Mazda truck and may be missing tv cable. I don't know. I'm sure someone here can help him.
I made this post so if he had trouble after signing up, making a new post that he could find me here. Thanks
Old 09-18-2010, 07:16 PM
hey bud
it is me scoobyfdoo.yes i am having alot of problems with the ford aod ,slipping hard to change and no tv cable yet .but i do have it.any ideas or suggestions will be great.thanks
Old 09-18-2010, 07:24 PM
Duntov's Avatar
Help Aod!!
Well that was a quick sign up.. Now we'll just have to wait for a Ford Guy to notice us. glad you signed up. It's a good site.
Old 09-18-2010, 07:44 PM
Duntov's Avatar
I mis-titled the thread We're alone on here! lol.
KKnow what Scoob? You need to start a new thread under this trans rear end thing. Because I unwittingly named the thread "Hey Scoob over here"............................................. .................. No one's going to pay attention to that... We'll be here waiting for days for an AOD guy. Need to name it "AOD HELP" or something like that. You can see at the bottom that it's just you and me on here..
If you can't figure out how to start a new thread call me and i'll help..
Also I sent you a PM
Old 09-18-2010, 08:05 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
well i noticed you guys. just not a Ford guy...sorry...
Old 09-18-2010, 08:19 PM
Duntov's Avatar
Knew we couldn't hide forever!
Cool, good to see ya ChevyKid
I'm going to start a new thread called AOD HELP. Maybe we'll get something going on it.
Old 09-18-2010, 08:46 PM
Duntov's Avatar
So Scoob Put an AOD in his MAZDA pickup and my understanding is that it's slipping intermittently and and won't shift without manually putting it in the gear you want.
I don't think he has a TV cable on it? Needs a ford Transmission guy.
I POSTED FOR HIM BECAUSE I'M NOT SURE HE FOUND THE NEW THREAD BUTTON.
He just signed up today...welcome Scoob
Old 09-18-2010, 09:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I merged your other thread together with the discussion on the AOD.
There is a mention of the TV not hooked up on the AOD.
This connection from the trans to the throttle at the carb / EFI on the engine MUST be hooked up and calibrated correctly. Chances are the trans is burned up already.
The AOD hook up of the Throttle valve linkage is far more critical than a 700r4 GM trans
Old 09-18-2010, 10:00 PM
Duntov's Avatar
tanx
This connection from the trans to the throttle at the carb / EFI MUST be hooked up and calibrated correctly. Chances are the trans is burned up already.
I thought so but wanted him to hear it from an expert. I really appreciate your efforts on the new member's thread. I'm sure he'll enjoy the forum. watchatinkboutdatScoob?
Old 09-19-2010, 01:11 AM
JeffB's Avatar
Running a Ford AOD without a TV cable is giving it a death sentence,it can fry the 3-4 pack within the first 10 minutes(if it isn't already) DO NOT run it until you get that taken care of.Here are the two best sites to help you: www.becontrols.com/tech/tech.htm and www.clickclickracing.com I suggest you read,read and more read the info there before posting a question on the sites you will learn plenty!
Old 09-19-2010, 09:24 AM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Welcome to hotrodders scoobyfdoo, it's great to meet ya. You will need that tv cable in order to get the aod to shift correctly. Sadly it is one of those things that ford incorporated into their transmission's in order for them to shift correctly. Many a mustang has had their transmissions removed because the tranny's started slipping, only to find out the tv cable was out of whack.
Here is a link to my website where i wrote a how to on adjusting the tv cable: http://www.insanemustangs.com/forums/15513-post4.html
Hope a link is okay? I am not using the link for anything other then helping a member of hotrodders.
need help with ford AOD information n00b Transmission - Rearend 6 04-30-2007 09:38 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
87 Ford AOD conversion to C6 johnc486 Transmission - Rearend 3 08-09-2006 06:52 AM
Ford AOD shifting hard??? KFXrider88 Transmission - Rearend 3 07-03-2006 01:04 AM
AOD ford transmission melbishop Transmission - Rearend 9 04-11-2002 01:29 AM
