Ford AOD question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 07:53 AM
octanejunkie's Avatar
Registered Looser
Last journal entry: Background: why I am here
Ford AOD question
Will and AOD out of a 1991 mustang bolt up to either a 302 or 351W engine going into a '67 mustang?
Old 02-25-2011, 11:45 AM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
Yes indeed it will. keep in mind that you will need a "164 tooth" flexplate. If you are using an older 302 (not a 5.0) or a 351W you'll want a 28 ounce imbalance flexplate. I get mine at the local parts store for about $65 last I got one. I ask for a flexplate for a "1991 Ford Crown Victoria with a 5.8 engine."
Now if you end up using a 5.0 engine you'd just pick up a stock 1991 Mustang 5.0 flexplate.
66 ford c4 question Stangman196700 Transmission - Rearend 3 11-12-2008 10:27 AM
Ford 6 question/help fishilps Engine 7 05-12-2008 09:32 PM
Ford question anthonyc Hotrodding Basics 15 04-04-2007 03:14 PM
32 Ford, 39 Ford tailight question. deere Hotrodding Basics 3 11-05-2006 07:00 PM
Ford 5.0 question?? Steve-0321 Engine 7 08-07-2006 11:46 AM
