-   -   Ford AOD question? (http://www.hotrodders.com/forum/ford-aod-question-223081.html)
allgaragework 08-19-2012 04:43 PM
Ford AOD question?
Ok I have a 65 ford mustang that I have put a Ford AOD tranny in and I drove it arround the block and found out right away that the tranny wanted to shift up to 2nd and 3rd quickley. I asked arround and checked on line and found out that I needed to connect a Loakr kick down cable also I fegured out how to set it so I can adjust the cable correctly with the help of some guages. It sounds like with the oil temp arround 150 degrese and the tranny in nuteral I should have about 30 to 35 lbs pressure and when it is in park it should between o and 5 lbs. This should make it safe enough for me to drive without burning it up. Please let me know if I mised anything. I ordered the guages on the net and am waithing for them to get here .:confused:
jaslong 08-19-2012 05:19 PM
been about 2 years since i did mine but that sounds about right i set mine right at 35 with the lokar cable I am pretty sure the cable comes with instructions on how to set it.:thumbup:
allgaragework 08-19-2012 09:36 PM
Cool!! the tranny shop scared the bejesus! out of me and gave me gloom and doom if I didnt do it right. I guess they were just wanting to help save me from burning it up.
Thanks:welcome:
JeffB 08-20-2012 02:45 AM
One of the guys in my Ford Group posted this: you will also find lots of info here: Click Click Racing - Click Click Racing and check out the Tech section here also: http://www.becontrols.com/faq.htm
allgaragework 08-20-2012 06:49 PM
Yes I seen this vedio and it helped me alot! thanks all i need now is to wait for my gauge to come in and I will get it done. Thanks again:)
