Ford AOD shudder - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2013, 08:07 PM
junkyardjeff's Avatar
Ford AOD shudder
I have a 89 crown vic that as soon as the trans goes into 3rd there is a shudder and slow speeds,I thought it was a miss so I tuned it up with new plus,wires and distributor cap but still the same. All the old plugs were burning good and all the same so I doubt it was the motor,when the shudder comes on I can put in neutral and rev the motor and no shudder so its getting me thinking that the torque convertor could be going bad so anyone have any ideas.
Old 05-20-2013, 10:23 AM
rick 427's Avatar
Last journal entry: The 32's
Lube guard has a product under the moniker of ''Dr.Tranny instant shutter fix''...Find a bottle of it, and pour it into the trans....problem solved...That stuff works!
Old 05-20-2013, 01:37 PM
JeffB's Avatar
Not unusual with an AOD,replace the boost valve and get the kit Baumann Electronic Controls you'll think it is the best bucks you spent on your Ford.
Old 05-20-2013, 02:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since an AOD does not have converter clutch setup like most domestics. The shutter may not b the converter. Although There is a splined hub that drives in 3rd gear. It is spring loaded. It mayy be bad. The lubegaurd is a quick test. Mayb it will help
I want to adapt a flathead FORD to a Ford metric AOD 53fordpkp Engine 1 10-01-2009 06:12 PM
Ford Aod 49fordp/u Transmission - Rearend 3 09-14-2009 12:55 AM
Ford aod to t-5 cferrell84 Transmission - Rearend 8 06-10-2008 06:21 PM
Ford AOD bct Transmission - Rearend 5 06-06-2007 06:51 PM
ford aod waynegray Transmission - Rearend 1 01-10-2007 07:22 PM
