-   -   ford AOD transmisson (http://www.hotrodders.com/forum/ford-aod-transmisson-231892.html)
billyjoebaney 04-15-2013 11:44 PM
hello im new but im having problems with a 1985 aod trans with carb put trans back today and it wouldn't take any gears forward or reverse any ideas
cobalt327 04-16-2013 12:43 AM
Torque converter bolted up to the flexplate?
Full of ATF?
Shifter connected and adjusted?
Drive shaft connected?
Rear wheels on the ground? ENGINE RUNNING??? lol
billyjoebaney 04-16-2013 10:23 AM
yes everything is hooked up and yes the truck was running lol
JeffB 04-17-2013 02:28 AM
Did you have the pan off and make any changes to the valve body? AOD's must have the TV cable PERFECTLY adjusted or it will fry within minutes.You can find a ton of troubleshooting info on AOD's here: Ford Transmission Forum
pricesgarages 04-17-2013 07:40 AM
is that the orgigional trans to the vehicle flywheel offsets are diffrent and can do damage to the pump
billyjoebaney 04-19-2013 02:39 PM
no I just pulled it back to check the flywheel put it back now nothing I pulled the line off of cooler no fluild pressure any ideas before I scrape this project:mwink:
