ford AOD transmisson - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 10:44 PM
hello im new but im having problems with a 1985 aod trans with carb put trans back today and it wouldn't take any gears forward or reverse any ideas
Old 04-15-2013, 11:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Torque converter bolted up to the flexplate?
Full of ATF?
Shifter connected and adjusted?
Drive shaft connected?
Rear wheels on the ground? ENGINE RUNNING??? lol
Old 04-16-2013, 09:23 AM
yes everything is hooked up and yes the truck was running lol
Old 04-17-2013, 01:28 AM
JeffB's Avatar
Did you have the pan off and make any changes to the valve body? AOD's must have the TV cable PERFECTLY adjusted or it will fry within minutes.You can find a ton of troubleshooting info on AOD's here: Ford Transmission Forum
Old 04-17-2013, 06:40 AM
pricesgarages's Avatar
is that the orgigional trans to the vehicle flywheel offsets are diffrent and can do damage to the pump
Old 04-19-2013, 01:39 PM
no I just pulled it back to check the flywheel put it back now nothing I pulled the line off of cooler no fluild pressure any ideas before I scrape this project
ford aod transmisson
I want to adapt a flathead FORD to a Ford metric AOD 53fordpkp Engine 1 10-01-2009 05:12 PM
Ford Aod 49fordp/u Transmission - Rearend 3 09-13-2009 11:55 PM
Ford aod to t-5 cferrell84 Transmission - Rearend 8 06-10-2008 05:21 PM
Ford AOD bct Transmission - Rearend 5 06-06-2007 05:51 PM
ford aod waynegray Transmission - Rearend 1 01-10-2007 06:22 PM
