Ford Autolite 4100 jets? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 06:46 PM
62galaxiguy's Avatar
I broke a jet in my 4100 when rebuilding (didnt use a jet wrench but a large screwdriver).Where can i get jets for this carb.Will holley jets fit? THe carb # iis C2aj
Old 01-16-2007, 08:56 PM
http://www.ponycarburetors.com/defau...ge=carburetors might have something.
Old 01-16-2007, 09:22 PM
FEDDO's Avatar
autolite
I know a man tha rebuilds these carbs and he has some jets. let me know the size and i will ask him. do you have any 4100 carbs with the 108 on the ft bowl? thanks, jim.
Old 01-16-2007, 10:24 PM
woodz428's Avatar
Troll Hunter
Don't know what # you need, but the Autolite 2bbl uses the same jets and there are tons of them around the junk yards( is that the correct term now days?). FEDDO...108s???? I usually see high 50s and some 60s,but 108s????
Old 01-17-2007, 02:03 AM
aka Duke of URL
The early 4100/2100 uses HOLLEY jets until 1963 then went to FORD specific. If the jet has just the orifice size stamped, it is HOLLEY. If the orifice size has F behind it, it is FORD specific.
PONY CARBURETORS supposedly has a good selection of the later FORD specific jets.
Old 01-17-2007, 06:12 AM
FEDDO's Avatar
autolite
woodz the number on reffered to is the carb size. 108 is a 525 cfm, 112 is,a 600 cfm. I thought i said (on) the left ft bowl.
Old 01-17-2007, 07:11 AM
woodz428's Avatar
Troll Hunter
I learned something. The only Autolites I have are '64 and later and when I had earlier cars with them I put a Holley or Carter on. Youthful enthusiasm I guess.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 07:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 04:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
