Ford Automatic Transmissions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2013, 10:38 PM
What is the advantage of Ford 4R7OW transmission over the Ford AOD Transmision
Old 05-18-2013, 05:31 AM
4R70W is electronically controlled, has a higher torque rating, a better gear set and is more durable.
Old 05-18-2013, 06:12 AM
Thank`s TommyK
Old 05-18-2013, 11:57 AM
JeffB's Avatar
To learn about both go here: Click Click Racing - Click Click Racing You can upgrade the AOD with 4R70W internals and stay non-computer or shell out some $$$ for this: The US Shift Transmission Control System Your 3.8 V6 will probably be fine with a perked up AOD,the 4RW70 mods are really needed for 400+ HP applications.
Old 05-18-2013, 10:11 PM
Thank`s
Thank`s JeffB
Will see who can tell me what 4R70W internals I will need.
Old 05-19-2013, 12:22 AM
JeffB's Avatar
Thank`s JeffB
You will find that at clickclick,Silverfox the moderator can hook you up with the parts you need.Be sure and spend time in the "sticky" section and do a whole bunch of reading:General Click Click Tech
Old 05-19-2013, 08:24 AM
Thank`s Again
Thank`s Again JeffB
I checked out that site It is just what I need.
Thank`s a Bunch
Old 05-20-2013, 04:55 PM
I had an AOD that was originally behind my 5.0L. After doing the research, purchasing a very low-mile 4R70W and US Shift controller was cheaper than rebuilding the AOD with the beefed-up parts. The bonus was the added control the electronic trans gives me. One drawback is the 4R70W is 1" longer, so the mount is 1" further back. I've had to modify my trans crossmember to work.
Old 05-20-2013, 05:38 PM
Thank`s Dads Blue Ford
I Appreciate your info . It helps to know just what I maybe getting into.
Old 05-28-2013, 03:32 AM
If you a looking for the highest torque rating, Ford also has the heavy duty 4R100 that is used in trucks. However, the 4R100 is about 5 inches longer than the 4R70W, so it requires a different mount and a much shorter driveshaft.
Bruce
Old 05-28-2013, 06:54 AM
Bruce Thank`s for the reply and info.
For my Purpose of towing my car hauler it may be just the ticket!
Thanks Again
Floyd
Old 05-28-2013, 06:09 PM
If you install a 4R100 and use a high capacity stacked plate transmission cooler (Long LPD, etc.) it should handle your towing without any problem.
Bruce
How important is "Starting Line Ratio" for automatic transmissions? DEMONSPEED Hotrodding Basics 6 06-15-2010 11:18 AM
Matching ford transmissions ford 4.9 Transmission - Rearend 3 10-15-2008 03:45 PM
Ford Transmissions wishnevsky Transmission - Rearend 13 04-18-2006 03:06 PM
Ford Flathead to Ford automatic c4-kit? bigjim Engine 4 01-05-2005 02:11 PM
