Ford Axle Swap 28->31 spline ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2006, 10:01 AM
bskaggs's Avatar
Hello all,
I looked around but found no info on this...
Maybe someone can help.
I have a couple of Chevy circle track cars that run 9" rearends with 31 spline/ 5 on 5 axles. We are building up enduro cars and have access to a cheap housing that is already setup for Chevy suspension, but it is 28 spline, 5 on 4.5 setup. I have several extra hog-heads (31 spline) and tons of old 5 on 5 wheels. So I was going to convert everything over so that my hog-heads and wheels will fit.
I do not have access to it until after regular racing season. I need it built for the enduro one week later.
What is involved in switching that? Are the races in the housing the same? Can i drop in the correct length axle and be good. I am pretty sure i will need bigger seals since the axles are fatter, but i am not sure.
Any help or suggestions would be appreciated.
Thanks ahead,
Old 07-06-2006, 01:13 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Big axles come in big bearing housings, of which there are 2 types of seals and bearings.
Some have tapered roller bearings that are lubed by the diff lube.
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 04:31 PM
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 07:30 PM
Ford 9" 28/31 spline quickie 85Sierra Transmission - Rearend 3 08-17-2005 10:37 PM
1937 ford axle DollarDan_RoadRage Suspension - Brakes - Steering 8 07-11-2004 03:57 PM
striaght 6 swap into a 55 ford truck brett 6868 General Rodding Tech 1 06-11-2004 11:51 AM
