ford axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 01:01 PM
ford axles
does anyone know what type vehicle can i get a set from, that measures about 51-52 inches across form backing plate to plate?. i was told my rear end came out of a late 50s model station wagon..not sure though,i need a passenger side axle do any of the 70s model lincolns come with a posi unit?
Old 11-20-2005, 01:33 PM
S10xGN's Avatar
Gotta love a turbo!
Directly above is a sticky called "Axle Information"... give it a look.
Russ
Old 11-20-2005, 08:12 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Is it a 9 inch Ford ?????
If you want help you have to give us a little help here.
If it is a 57-58-59 Ford 9 inch, then most every 60s Fairlane 8 or 9 inch or 70s Granada 8 (eight) inch axles drop right in.
Nobody measures rear axles by the housing length, the correct measurement is wheel flange to wheel flange, and the Fords listed are all 57 1/2.
There were a few cars built with BIG bearings or even HD axles. Check the backing plate flanges for dimensions between bolts for i.d.
9 inch posi units were optional on all Ford products.
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Pulling axles on Ford 8" Whippetguy Transmission - Rearend 8 10-24-2005 07:10 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 09:09 PM
78 Ford LTD (full sized) with eaten axles T Hoose Transmission - Rearend 5 11-23-2003 03:47 PM
