ford axod tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2011, 03:14 PM
ford axod tranny
have a 93 sho taurus rebuilt the tranny axod !! works perfect till you shut car off then takes a dump !! fiddle with valve body etc and fine again till shut car off!! dang
Old 07-23-2011, 05:37 PM
tnsmith10's Avatar
when will it rain???
what do you mean the trans takes a dump? the trans quits working afterwards? the trans leaks a lot of fluid when you shut the car off? if its leaking, where does it look like the fluid is coming from?
Old 07-23-2011, 06:04 PM
axod tranny
after shut off mushy 1-2 shift and no 2-3 shift with this trans if no 3rd you aint gonna get 4th!! have had apart 3 times !!air checked all clutches!! when is working is perfect takes wot with no slip in all gears till shut off then no upshift !! removed valve body today and dissasembled and cleaned !! same thing ran perfect til shut off then soft 1-2 shift and no 2-3 shift
Old 07-23-2011, 06:09 PM
sho tranny
have 2 friends that own tranny shops!! worked for 1 of them for a bit !! they scratchin their heads on this one also!!
Old 07-24-2011, 04:53 PM
tnsmith10's Avatar
any codes in the system read with something other than a code reader? have you checked that the trans is getting command to shift when its acting up? is the range sensor set properly and checked with a scan tool for proper operation? have you made sure the epc solenoid and shift solenoids are good? whats the condition of the internal harness? and lastly, what was problem with the trans before rebuild?
Old 07-24-2011, 05:01 PM
axod trans
harness is good !! solonoids are new !! next step is hook up to transstar 2000 will see!!orig prob was failed pump bearing and seal trans worked fine just was forcing fluid out converter seal !!again fiddle with valve body and works fine till shut off then ??????? btw no clutches or bands were bad just put new in as had apart !!
Old 07-25-2011, 07:19 AM
tnsmith10's Avatar
i take it you mean the tran-x 2000.
you didnt mention if the were any trouble codes stored.
i do have a curiosity question though, you say pump bearing and on this trans, it uses a bushing in the converter, not the pump. so did you replace the converter or is this bearing somewhere else?
was the pump taken out and the the pump shaft and sleeve checked for wear while it was apart?
from what your describing, this is not a valve body issue, if you had the drums apart to replace the clutches, id say there is a possibility that you cut a lip seal on assembly, or it has a cracked piston. which is what it sounds like from what your describing.
Old 07-25-2011, 08:27 PM
axod
there are no codes stored !!also there is a bearing/seal combo in the pump housing itself that is a common failure in axod and ax4n new bearing is wider and seal is seperate on upgrade which gives more surface for pump shaft to ride on!! when this bearing fails wipes out bushing in valve body and puts pump presure to converter seal hence the leak!!all above mentioned are new!! just don't wanna shift !!am gonna stick with sticking valve body for now and clean again !! flush cooler and see what happens !! when it works is perfect!! would not hold wot in all gears with a torn lip seal!! also would have trash in pan from slippage!!
Old 07-30-2011, 12:18 PM
problem solved
just call me ******* !! after carefull consideration of sequence of events in overhauling this tranny solution came to me in middle of night!! you forgot to flush cooler ******* !! pulled and cleaned valve body flushed cooler!! new filter and fluid !! tranny works fine note to self pay attention ******* thanks for all your input guys !! was my own fault!!
Old 07-30-2011, 12:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sledsonhigh;
You need to stop bouncing of the profanity filter. This board is a PG rated forum per the admin guy Jon.
Old 08-01-2011, 12:57 PM
Glad you fixed the problem, sometimes the answer really is in going back to basics. However, please use more standardized punctuation and less profanity. Thanks Crosley and TNSmith10
87 Ford AXOD Trans Squire 406 Transmission - Rearend 1 07-12-2007 06:09 AM
1993 Taurus Axod/E...MLP? awbazar Transmission - Rearend 6 07-02-2006 06:12 PM
Ford AXOD or AX4S Help Native Gearhead Transmission - Rearend 6 06-01-2004 10:20 PM
AXOD Ford trans rebuild advice. 4 Jaw Chuck Transmission - Rearend 22 03-16-2004 05:37 PM
AXOD-E Transmission, swapable? transmission fried Transmission - Rearend 5 05-27-2003 07:05 PM
