Originally Posted by bigblocktorino
351 modified and 400 are both big block bellhousings like the 429 / 460.
1.) Will they bolt up to the 429 / 460 ? and
Yes, same mounting pattern.
2.) if they do will they give the same clearance as the big block bellhousing?
That would have to be a light truck application. I would have to research that but assume that it would be the same as FORD used the F/4/S overdrive derivative the 4/S/OD in some period light truck applications.
What are you trying to do?
