Ford Big block 4 spd bellhousing
Is the ford 4 spd top loader manual transmission bellhousing the same depth and width for a 460,428, big block 429 cobra jet motors.
My problem is as follows; I have a 76 Ford Gran Torino with a 460 motor and a 4 spd top loader trans. This was a custom install when I bought the car, it was not a factory option.I have put a new matching clutch set-up in the car and rebuilt the trans. Now that everything is new and installed and a matching set (clutch, pressure plate, throwout bearing and pilot bearing) I am constantly grinding gears during shifting. The clutch does not seem to be releasing far enough. I was told by a Ford Enthusiast that the bellhousing for a Ford 429 Big Block Cobra jet is bigger and deeper than other big block bellhousing and that I need that for clearance. These are hard to find and very expensive and would like to know before I consider it the only solution. Any answers? Thanks. |
It sounds more like a clutch release problem. Use diaphram or finger style? Did you measure air gap between disc-flywheel/disc/plate when fully released? New pilot bearing? Input shaft bearing new? Needle bearings OK where main shaft enters input shaft? Any binding of throwout bearing on bearing retainer? Equalizer shaft bushings? |
Thanks alot for your input!!! How about this???
351 modified and 400 are both big block bellhousings like the 429 / 460. 1.) Will they bolt up to the 429 / 460 ? and 2.) if they do will they give the same clearance as the big block bellhousing? Also is there any differance between a truck or car bellhousing??? Thanks alot for any info!!!!! |
What are you trying to do? |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Big block ford 390/391 | StevenC | Engine | 4 | 06-16-2005 09:28 PM |
| Small Block - Big Block, what are they? | Juicer | Hotrodding Basics | 49 | 09-01-2004 12:16 AM |
| small block ford parts interchange | k-star | Engine | 3 | 01-16-2004 09:35 AM |
