Ford Bronco 2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2003, 09:36 AM
Post Ford Bronco 2
The Bronco 2 has a 2.9 v6, and it will not run without flooding itself out with the TPS sensor plugged in. I can unplug the sensor and it will run, but very rough. I was wondering if I could take off the throttle body and put on an intake and carb, and do away with the computer system completly???, will it still pass inspection??? Someone please me I am getting really frustrated.
Old 03-26-2003, 02:07 PM
aka Duke of URL
Question
Why not just have the ECM scanned and see what is wrong with the system? It would be much easier and cheaper than tearing the EEC and FI off. I am not sure if there is even a carb manifold available for that series. And, according to how tough the state emission laws (it is definetley a no-no Federal) are, you will make the vehicle illegal to operate.
Old 03-26-2003, 09:25 PM
Andrew7dg's Avatar
Post
there is no intake for the 2.9L. accually it is a pretty good fuel injected system to be running on the engine. Like said before just have the computer scanned. I could be wrong because i don't know much about the engine but have the O2 sencer checked. I know when those go out the computer system floods the engine.
Old 03-27-2003, 04:28 AM
Pontiac Knowledge Base Editor
Post
On the drivers side of the intake on the rear there is a fuel pressure regulator. That is the problem. It takes 15 minutes to replace it.
Old 05-13-2011, 10:57 AM
An't FI nice as for inspection just take it to some one you know or find one of your buddy's that knows some one. About all they do on the older models is jack them up off the grown,look at the tires and pipes to make sure they an't about to fall off,smile take your money and wish you well. They like the older one's as all but about $.50 goes in there tilt. Don't have to hock there computer to them. IF it will run w/out the TPS sensor sound like the sensor is the trouble BUT it may a FORD only part your local Advance or who ever you use for parts can tell you.good luck. Oh I did have to replace one on my MUSTANG a 2000 model and FORD only replacement part.
OLDROD
Old 05-14-2011, 05:34 AM
willowbilly3's Avatar
Last journal entry: Body mods
2.9, probably still OBD1, not 2. No data stream from the computer, you have to use a break out box to extract the info other then blinking the codes. Almost all of the components can be checked with a DVOM. If you are going to start throwing parts at it without a proper diagnosis, start with the O2 sensor because those should be changed once in a while anyway, just like spark plugs.
A simple fuel pressure test would show if you need the regulator.
