ford bronco hyd clutch conversion. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2005, 09:30 PM
Jared's Avatar
I know this is a truck question but I figured someone might have some ideas. I have a 83 full size bronco frame with an 86 full size body and a 72 ford 429. I am putting in a 77 NP 435 tranny with a NP 205 transfer and I was wondering if any fords are running a Hyd clutch that I could retrofit into my bronco. I plan on going to a Centerforce Dual Friction clutch and I want to maintain a light clutch, I dont have any of the linkages as of yet but if I decide I want to go with a linkage system I can get one from the salvage cheap, or a hyd from there too. I have 32" tires currently and 3.50 gears. Daily driver mostly winter weather and off road; mud, snow, minor rock crawling. any ideas? thanks, jared
Old 05-20-2005, 10:11 AM
dei8fan's Avatar
Registered Brain Surgeon
Im not too much on fords and I cant remember if the 429 is the same bolt pattern as a 460. Ford had hydraulic clutches on 460 4sp trucks.
Interchange on it is:
1 FTF250 84-87 8-460 (7.5L)
2 FTF350 84-87 8-460 (7.5L)
89 and up trucks had integral bell housing 5speeds
Maybe this will help
Old 11-07-2007, 04:00 PM
ajbcc2's Avatar
Last journal entry: frankenstude too
i had a 91 ford f150 that had a hydraulic clutch..
Ford Bronco 2 Cruz London Engine 5 05-14-2011 04:34 AM
Bellcrank or Hyd Clutch? 6t6novass Transmission - Rearend 1 06-10-2004 10:25 AM
81 ford bronco no spark gm3bud8 Engine 8 01-05-2003 05:18 PM
'89 Ford Bronco II Lift rc4lax Body - Exterior 3 12-30-2002 09:27 PM
Ford Bronco and fuel injection cbiggs Engine 2 06-04-2002 12:03 AM
