Ford Bronco NO Fire - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 02:32 PM
Ford Bronco NO Fire
I have a 1986 Ford Bronco. I think it might have an 88 engine. It died on me and I have replaced Inertia Switch, ignition module, distributor, wires, plugs. Fuel pump is working but I cannot get any Fire!!! Damsel in Distress...Please Help!
Old 05-11-2011, 09:58 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi HotLana
Using a digital volt & ohm meter check the voltage to the coil if it is 12 volts go to this next step.
Use a 12 volt test light put it on the coil negative have somebody try to start the car. The test light should blink pretty fast. If it doesn't blink replace the pickup in the distributor.
Check the ground wire by the computer in the passenger side kick panel. There is a relay in their also hold on to it, it should pulsate when trying to start.
Rich
PS There was a recall on the ignition switch.
PS's Do you know how to jump start a ford at the solenoid?
Old 05-12-2011, 02:22 PM
Is it a BRONCO 11 or the full size? I have a 85 BRONCO 11 and every time I lose fire it has been the module (every year or two) I keep one in the glove box. I have had trouble with the computer once as FORD did have trouble with a few did't recall them but did replace mine at no cost. The bad news it will take some one with the rite machine to check it. The computer caused a skip in cool wet weather BUT They can just quit . GOOD LUCK.
OLDROD
Old 05-12-2011, 10:49 PM
Ms Lana, on an 88 engine there'll be a crank position sensor
(CPS) located near the harmonic balancer at the front of the
engine. Maybe the sensor is bad, or the wiring to it is broken
or loose. Make sure the sensor plug-in is secure.
Ford Bronco 2 Cruz London Engine 5 05-14-2011 05:34 AM
76 Ford Bronco (new guy) tonyz Introduce Yourself 2 08-05-2008 11:36 AM
1989 Ford Mustang and 87 Ford Bronco fordman83 Introduce Yourself 4 03-23-2007 11:54 PM
86 ford bronco debodt Engine 1 04-19-2006 12:45 AM
88 ford bronco 2 troublega Engine 2 04-15-2006 03:27 AM
