-   -   Ford C-4 trans question (http://www.hotrodders.com/forum/ford-c-4-trans-question-219478.html)
Groucho 05-16-2012 03:48 PM
I got a 72 Ranchero today. 302/C4. It shifts a little late and harsh 1-2, and I have to let off the gas to get it to shift 2-3 when up to temp. It's fine when cool. I though the modulator was plugged to the wrong source, but it's not. I'll check some more in the morning. But, any ideas guys? Thanks
RWENUTS 05-17-2012 08:00 AM
If your modulator is adjustable turn it ccw about 6 turns and see if it gets better. You might need to turn it out even more than that.
Pull vac hose off and look inside. Should be a slotted screw head in there.
Groucho 05-17-2012 09:56 AM
Cool, I'll look
