Ford C-4 w/ reverse valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2009, 08:55 PM
RSM's Avatar
RSM RSM is offline
Whats the deal with a reverse valve body? Is there some advantage over a regular shift transmission? I have a Ford I bought with a reverse valve body tranny and don't really know anything about them. Can someone enlighten me?
Old 12-16-2009, 10:30 PM
ericnova72's Avatar
More for Less Racer
The reverse shift pattern allows a shorter fluid path through the valvebody for a more solid shift. The other benefit is you are shifting away from the neutral and reverse gates, so there is no chance to get into neutral or reverse by accident at high speed
Old 12-17-2009, 03:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Right on,
Cole
Old 12-17-2009, 07:27 PM
RSM's Avatar
RSM RSM is offline
I kinda figured that about the shifter. I have a TCI Thunderstick...(1/4 stick) which is impossible to go from neutral to reverse unless you hit the lockout. I couldnt figure out why my shifter wouldnt work on this transmission until I figured out it had a reverse valve body. So not knowing the reason for it...I asked. Thanks for the info!!
Old 12-17-2009, 08:49 PM
ericnova72's Avatar
More for Less Racer
Are you aware you can buy different gate plates for this shifter to convert it to reverse pattern or 2-speed, 4-speed OD, etc use??
Old 12-17-2009, 09:08 PM
RSM's Avatar
RSM RSM is offline
The old shifter was a reverse pattern so I took the gate off of it and put it on my shifter which is new. Works like a charm!!
anyone know how to make a reverse shift pattern 727 valve body? the nitro man Transmission - Rearend 0 06-13-2009 11:18 AM
How to clean a valve body? fiscus Transmission - Rearend 1 04-06-2005 08:48 PM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
th350 manual valve body on STREET? MuscleBlock81 Transmission - Rearend 2 10-30-2003 08:46 AM
700 R4 Valve body ???'s juveteach Transmission - Rearend 1 09-15-2003 07:53 AM
