Ford C4 auto shifting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2013, 05:37 PM
woody51's Avatar
Hi all
I have a recoed C10 in my car and it has a strange shifting problem 1st and second (has a stage three shift kit)
Normal driving it shifts into second in the first few feet, but if I tramp it it holds a bit better, I tried adjusting up the modulator but with very little result, so I changed it and still the same.
When the trans gets hot and I idle along in slow traffic it appears to "crash" between 1st and 2nd continuously and I have to move the shifter back to 1st
Any Ideas ??
Old 05-22-2013, 11:47 AM
Wiki Edits: 85
Since you are posting mostly to an American audience you should use American terminology for your transmission. Almost no one in the U.S. has a clue what a C10 transmission is, so most will not post even if they know the answer to your problem.
The Following User Says Thank You to mmerlinn For This Useful Post:
woody51 (05-22-2013)
Old 05-22-2013, 04:33 PM
woody51's Avatar
Not sure exactly what you mean ? Or is it that the C10 was an Aussie box?
Old 05-22-2013, 06:47 PM
Banned
over here mate fords older trans..
mid 60's up are
c4
c6
fmx
aod
the c6 was stronger than the c4
the fmx was the redheadedstepchild.
and for whatever reason ford built the aod off the fmx
the image below will give you the american name listing, match up pan shape and then we'll know what you got
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 05-22-2013, 11:08 PM
woody51's Avatar
mid 60's up are
c4
c6
fmx
aod
Thanks for that ! It appears now after some more research that what I have is what you guys call a pan filled C4 or later C4
Seems that a C10 is an Aussie term that someone invented
Old 05-23-2013, 01:45 AM
Banned
now the ford guys or tranmission guys can help ya.
Old 05-23-2013, 07:09 AM
woody51's Avatar
Only if they read past the Topic Heading
Old 05-23-2013, 06:48 PM
Banned
might want to repost with c4 in title
Old 05-24-2013, 03:34 AM
woody51's Avatar
Yeap think you're right
Old 05-24-2013, 05:06 AM
Banned
send a note to a mod, asking to change the c10 to c4 in the title..
just click the triangle with a ! in it. and it'll go to the mod's
this is what you'll click in your first post
Old 05-24-2013, 05:07 PM
woody51's Avatar
Hi all
I have a recoed C4 in my car and it has a strange shifting problem 1st and 2nd (has a stage three shift kit)
Normal driving it shifts into second in the first few feet much too soon, but if I tramp it it holds a bit better, I tried adjusting up the modulator but with very little result, so I changed it and still the same.
Any Ideas ??
I'm sorry if this seems a repeat thread but in Australia we call the pan fill C4 a C10 and I named the topic as that
Old 05-25-2013, 03:17 AM
woody51's Avatar
Ooops stuffed that up lol
2000 chev S-10 truck auto trans shifting problems rschatzel Transmission - Rearend 2 10-18-2011 01:35 AM
Manual shifting an auto bigdog7373 Transmission - Rearend 35 11-10-2010 02:24 PM
Ford AOD problems... Slipping Not Shifting Right Duntov Transmission - Rearend 10 09-19-2010 09:24 AM
manually shifting auto? Brian Morency Transmission - Rearend 9 11-13-2004 04:17 PM
Auto shifting to quick! chevelle327 Transmission - Rearend 6 11-25-2002 07:57 AM
