Because it shifts normally in drive, if I understand your post. I'd check the kickdown and modulator valve adjustment. You might first pull the hose from the modulator valve and see if it is leaking into the hose. The modulator is adjusted through the vacuum nipple with a small screw driver and clockwise delays shifting and counter clockwise makes it shift sooner. The kickdown is adjusted at the carb and is responsible for making the tranny downshift when you nail it. They need to both be adjusted correctly for the set-up to work well. You didn't say whether the tranny has had any work, if not some of the inner valves amy be a little gummy or have weak springs. Diagnosis from a distance without complete info is "hit and miss", at the best.
Well, it's not exactly a shifting problem, but I don't know how to call it better. I'll try to explain it once again. Lets say that the car is running, shifter in neutral, no pedals (brake, gas) pushed. if I move the lever to R position, the transmission reacts in less than second, and car starts to move backwards. But if I move lever to D, then for about 5 seconds nothing happens. It sits like still in neutral, and then finally the first gear comes on, car moves forward and everything is fine during driving. Until I need to put the D in from neutral again.
Sounds like my old '66 t-bird I had years ago. I'd start it up and have to wait about 5 minutes for it to finally engage. Come to find out the seals inside the trans had hardened badly and did not seal until it warned up some and finally softened up. Only cure for my problem was a rebuild.
Mark |
c-4 problem
This is an engagement problem. When you move the selector to drive, the forward clutchs should apply.
When they don't, or the ENGAGEMENT to drive is delayed, there will be a problem in the forward clutch circut. If the manual valve is lined up correctly [ linkage is correct ] and the transmission is full of fluid, and you have eliminated these things as a possiblity, then you must suspect a problem in the forward clutch circut. So what does this mean? Well if the c-4 has been around awhile, suspect hard seals in the forward clutch drum, itself. This was always a common problem. And by the way, I cut my proverbial teeth, on this transmission. Worn clutchs, are not out of the question, either. The metal sealing rings, on the pump, which seal the pressure, going to the forward drum, could also have "given up the ghost", as well. So check the easy stuff. If you already have and their ok, well then it may just be that this trans will be needing some major attention. Good luck! |
Common problem on a C4 type trany is the round O-ring in the forward drum to get hard and shrink. Usually these O-rings come out of the drum in pieces of hard rubber.
Check the aluminum piston inner diameter for a groove worn in from the hard O-ring
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Some new info: Found out that the trans is leaking oil from converter area. Just dripping when in neutral, and almost trickleing in gear. Haven't had a chance to pull it yet, but I'm trying to get there next week.
| 46 ford p/u model # ( WRONG ) ? | biglee550 | Suspension - Brakes - Steering | 19 | 03-17-2008 08:45 PM |
| T-5 transmission codes needed | xntrik | Transmission - Rearend | 4 | 09-06-2005 09:09 PM |
| Ford Flathead to Ford automatic c4-kit? | bigjim | Engine | 4 | 01-05-2005 02:11 PM |
| Ford C4 question | onebadmerc | Transmission - Rearend | 3 | 12-31-2004 10:18 AM |
| AOD into mustang | Stangman196700 | Transmission - Rearend | 3 | 12-16-2004 08:51 PM |
