ford c6 neutral safety wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2004, 01:31 PM
cboy's Avatar
Last journal entry: Finished
There is a circular switch on the shift lever of the C6 trans. which I believe is both the reverse lights and the neutral safety switch. There are four wires coming off the switch, two reds, a black, and a white/creme colored. Are the two reds for the neutral safety switch and the black & white for the reverse lights? (I suppose I could go test them but I'm feeling lazy and the garage is awfully cold today and I'd rather not blow a fuse crossing the wrong two wires).
I'm also posting this in transmissions.
Dewey
Always learning...and sharing what I've learned.
Old 02-11-2004, 05:18 PM
cboy's Avatar
Found my answer (gave in and went out there with my tester)
For future reference (somebody putting a shifter on a C6) The white/pink wire and Black/Red wire are for back up lights. The two red/blue wires are the neutral safety.
