I won't go back to the Edelbrock carb or the 2.75 gearing, but would like to try a 600 cfm DP to see if there is a difference performance wise. Thanks for your info and help also, Woodz.Ed Last edited by kleen56; 12-29-2008 at 10:38 AM. |
Joe Sherman runs 750s on his 289/302 builds approaching 400 hp with the factory iron heads. (I am just reporting it)
Proper calibration of secondaries of any carb is necessary for best performance. Vacuum secondaries need springs adjusted, and Edelbrock Air Valves often need adjusting also. Don't like or dislike any one type of carb based on a mismatch or mistune of one or two instances. Me, I like the Edelbrock (AVS preferred) for 80% of the uses. |
Hi-Po 289s cam from Ford with an Autolite( nice carb, but small) of about 465 cfm. Shelby used tri-y headers and a vacuum secondary 780 on his Hi-Rise( Edelbrock made, I believe).Shelby's were (the first year) just tamed race cars for the street, they ran a 3.89 gear and glasspacks with side pipes( side exiting, not traditional style sidepipes). One of my customers is an original owner of one,a lot of fun, but it was set up with the knowledge at the time and it has progressed much in the last 40+ years. You could take that same car and do some simple changes and it would be quicker than it is..with a smaller carb. Of course, that's a moot point, because he like most Shelby owners are unlikely to alter too much for fear of lost value. His in particular, because he IS the original owner and has every receipt he ever got. A side note for the Poncho fans, he had just purchased a new GTO about a week before and traded it in for the Shelby when he drove by the Ford dealer and saw it. Not many cars that generate that type of enthusiasm anymore. Wonder where that goat is??
*correction* right after I posted I realized that it wasn't a 780, it was a 715. They were the only ones that had "cathedral" bowls, the predecessor to the dual feed/center pivot style bowls. Last edited by woodz428; 12-29-2008 at 05:13 PM. |
http://www.buicks.net/shop/reference/carb_cfm.htm Check out the calculator..shows about 464 cfm at 85% VE.. the smaller carb will have a much crisper throttle response at normal driving speeds..You will not need a 650 unless you are seeing 6500RPM+ on the track..I would pick the 550 CFM as a good compromise..
Sam
moving to the engine forum.
I split off the carb discussion from the rear differential gear discussion.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
