Ford Cowl Vent query - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 01:51 PM
Hi
I've got a 1933 Ford Sedan. The cowl vent has a bulge on the inside if it, so I cannot fit the bug screen!
Most cowl vents I've seen for a 33 or 34 Ford have a flat underside. Does anyone know why this one has a bulge? ....could it be off another model - e.g. truck!. Any thoughts or ideas please?
thanks
Old 05-18-2009, 02:08 PM
powerrodsmike's Avatar
Wiki Edits: 161
Is the bulge in the vent itself? Or is it in the deflector? The sheetmetal was only 2 pieces, with the vent being one stamping and the deflector a seperate part, spotwelded to the vent at the factory. Sometimes the deflector is bent more than stock, which will hit the back of the bugscreen.
33-34 cars were not interchangeble with any 32-34 trucks, I do not know if a 35 or 36 truck cowl vent could have been modified to fit.
A picture would help.
Later, mikey
BE different....ACT normal.
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
38 ford cowl ? 38harry Body - Exterior 0 11-11-2008 06:51 PM
Ford C-4 in a 34 Ford Roadster RTY Transmission - Rearend 1 06-11-2008 06:27 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
M.S. requested joke thread hotrodit Off-Topic 186 12-20-2005 12:26 PM
