Hotrodders Bulletin Board
#1
Ford Crown Victoria '89 electrical probs
we took one fuse out that controls the radio, interior lights, power locks and power mirror adjustments....if I leave it in, it drains the battery. It is an annoyance to have this set up but I am dealing with it. Now I have rear driving lights out, brake lights work, just not driving lights. Looking for a schematic before we start playing with all the fuses. Any ideas on where to find this?
#2
re: Ford Crown Victoria '89 electrical probs
Welcome to Hotrodders. This forum is for introductions not questions. Please place your question where it belongs ...in the Electrical forum and someone will give you some answers and ideas.
#3
Welcome to the site delrays. This forum is for introductions. You will get more answers to your questions in the Electrical forum. Repost your question there and you'll get some results. Good luck solving your problems.
#4
Moving it there.
#5
Perhaps doc or vicrod will chime in incase i forgot anything but here is what i suggest. You already found the fuse that causes a current drain, now what i'd suggest is disconnecting all those mentioned components then hook them up one at a time and check for current draw by using a multimeter set for amps in the proper scale, between the negative cable and negative terminal. As far as the rear running lights check the fuse first, if ok check bulbs (i know i know) If those check out ok start tracing the wire and check for voltage at any junctions you find. Good luck and post back
Back to top |
Similar Threads for: "Ford Crown Victoria '89 electrical probs"
| 89 Ford Taurus SHO Engine | heyphilbert | Engine | 6 | 08-17-2006 09:55 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| '89 Ford Bronco II Lift | rc4lax | Body - Exterior | 3 | 12-30-2002 09:27 PM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
| 89 ford ranger/ tension pulley for serpintine belt/ anyone have one? | Doug Lavery | Engine | 1 | 11-14-2002 05:36 PM |
