ford cruise o matic - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2002, 06:09 PM
65galaxie500's Avatar
Question ford cruise o matic
any info about hese would be very helpful, are they reliable?
Old 11-16-2002, 06:33 PM
46DRIVER's Avatar
New Member
Post
I don't think you can put too much HP through them, i had a few years ago, if you leave em sitting too long all the seals and bands dry out on you. Maybe someone knows if there is a converstion kit to hook up a C6 to your FE? Is it a 390 or 352? or are we talking 289? If that's the case a C4 might do the trick, I may be way off base here tho. <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 11-16-2002, 06:46 PM
Post
its a 352 and the tranny seems to do just fine. its the first time ive owned a 2 speed automatic. ive got no desire to drag race or anything if i wanted to do that i probably would of went with something a couple of tons lighter. i intend to baby it, just trying to plan ahead for when it may need to be replaced or think about rebuilding.
Old 11-16-2002, 09:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Rebuild kits, torque converters, clutches etc. are all still readily available for the Cruise-O at regular prices. Should be no problem keeping it on the road for the forseeable future.
Old 11-16-2002, 11:50 PM
aka Duke of URL
Arrow
If it is a two-speed FM, you need to upgrade to either an FMX or C6.
FORD used the 2 speed FM in your application for the cost factor.
Old 11-17-2002, 09:54 AM
Post
You're going to need to get on the internet. It's a great place to find info for your projects. The following took all of thirty seconds on "Google". Just typed in fordomatic. Take a look;
<a href="http://www.autotran.us/fmkits1.html" target="_blank">http://www.autotran.us/fmkits1.html</a>
<a href="http://webpages.charter.net/1bad6t/c3.html" target="_blank">http://webpages.charter.net/1bad6t/c3.html</a>
<a href="http://www.dearbornclassics.com/galaxie.html" target="_blank">http://www.dearbornclassics.com/galaxie.html</a>
<a href="http://www.fordv8.hpg.ig.com.br/modelo.htm" target="_blank">http://www.fordv8.hpg.ig.com.br/modelo.htm</a>
<a href="http://www.fordclassics.com/carclubs.html" target="_blank">http://www.fordclassics.com/carclubs.html</a>
Those were just a byte or so of 620 sites located. A C-4 or C-6 will fall fight in if it is an FE. C-4 for a small block.
