Ford Cylinder Head Interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2012, 10:42 AM
GMCBEAST's Avatar
Hey guys, well was having some overheating issues in the wife's 2007 Explorer. I was hoping just a head gasket but looks like the heads didn't like the heat and one of them is cracked. Does anyone here know what all heads interchange on the Ford 4.0 v6? Will be going to the salvage yard this weekend and don't have a clue which heads will swap, and I highly doubt there will be an '07 Explorer there so I'd like to go armed with a list of alternates that will work. Thanks guys.
Old 04-09-2012, 12:30 PM
JeffB's Avatar
The salvage yard should have a Hollander Manual to verify interchanges,some wreckers specialize in a particular make so going to an all Ford yard would be a good bet but cost may be slightly higher but worthwhile in the long run since the part would have a limited warranty.
Old 04-09-2012, 07:58 PM
LATECH's Avatar
You can buy all new heads complete for 5-600 bucks. hardly worth the trouble of buying used/possibly cracked from a place you know nothing about.
If you know your salvage yard well then your OK.
Those heads are so prone to cracking that anything you buy should be checked VERY closley. Between surfacing and pressure checking and a valve job, the cost wouldnt be too m uch more to buy new.Just a thought.
Ford 300 six cylinder custom head Chris Kemp Engine 19 01-26-2016 09:56 PM
Cylinder head casting number Ford Ratoflic Engine 5 02-10-2011 07:05 PM
Ford 5.0 Cylinder Head ID help please sixty9santa Engine 10 08-23-2009 10:32 AM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Ford Small block cylinder head ID roys63 Transmission - Rearend 2 11-02-2003 06:58 PM
