Helping a friend out. I know nothing about Fords, especially diesels.
Anyway, he has an oil leak visible at the bottom of the balancer. Unlike SBCs, there isn't a timing chain cover behind the balancer but I'm assuming there is an oil seal on the crank behind the balancer.
I'd like someone to confirm this and provide suggestions on the best way to replace the seal.
Is it a pry out and replace process? Or, something more complicated?
it sounds like the timing cover seal has hardened up and/or the surface of the balancer the seal runs on has a groove worn in it by the seal,anyhow pull the balancer off,look for the groove,which is repaired with a speedy-sleeve kit,and hopefully you can replace the seal without removing the cover-plate. be sure to look to see how far up the engine the oil is coming from. It may be you just noticed it on the balancer,is it engine oil,or is it another fluid. It could be leaking from the intake to block parting surface.You may need brake clean to wash the old oil off first,then watch for the leak to re-appear
That is correct and if you put the wrong bolt in there and hit the timing gear it will cause the head to seize in the injector pump. Ruining the EXPENSIVE pump. About a $800 mistake
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
