Ford Diesel Engine Advice Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2005, 05:58 PM
edge's Avatar
Time is short, are you ready?
A friend of mine has a 1993 4x4 F350 pickup with a turbo 7.3 Liter engine with manual transmission. The 7.3 Liter developed a cracked block and is beyond repair (at a reasonable cost).
This is a work truck and he needs to get it back running quickly. He found a good deal on a recently rebuilt 6.9 Liter non-turbo and was told that it will bolt right in, and that the only modifications needed are to switch the intake w/turbo and harness for the glow plugs.
Since the 6.9 Liter is a non-turbo, it will have about 2 points higher compression.
Can a Ford 6.9 Liter diesel engine bolt in place of a 7.3 Liter?
If so, will the higher compression be a problem using the turbo, being it is a diesel?
Any help would be greatly appreciated. Thanks, Ed
Old 09-16-2005, 12:56 AM
aka Duke of URL
You may get a quicker answer -HERE-
Old 09-16-2005, 04:49 AM
edge's Avatar
Didn't even have to post a question and even found the answer without searching. Thanks for the reference, exactly what we needed. Ed
Old 09-16-2005, 07:17 AM
aka Duke of URL
THIS IS OUR MISSION HERE-
Old 09-16-2005, 08:43 PM
New Member
big swap
Both ford motors are International Harvester. Check with one of thier older mechanics tey will know one is a 345 block and the other I think is a 504 block. I don't know if it wll swap right in and check your fron end wheight it could realy mess you up.
An old Ford engine. What is it? bb53chevpro Engine 12 09-08-2006 08:48 AM
Ford GT-40 Crate Engine Questions 31rdster Engine 8 11-27-2005 02:32 PM
engine advice Sean N Engine 0 11-25-2003 01:15 AM
Ford Engine size Rancher Engine 6 11-23-2003 12:45 AM
460 ci ford engine help shootingstar General Rodding Tech 4 09-19-2003 09:49 AM
