Ford Duraspark distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 01:23 PM
boris_thespider's Avatar
I wiped out the distributor gear on my Duraspark distributor. I don't have a press, so I was tapping the new gear on with a socket and a small hammer. I had the distributor upside down on my bench with the top of the distributor shaft sitting on a piece of wood as I tapped the gear down. The gear is now in place and I still have my roughly .030 shaft play between the shaft collar and the housing. But now I noticed that the upper advance shaft has some up and down play also. I don't remember if there was any play at that point before I was tapping the gear down. Is this normal or do I have to fix something? Thanks...
Mike
Old 08-04-2010, 01:38 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
The up and down play on a Ford distributor is normal.I've replaced many when the old stators were shot.Never had a comeback .You probably had it before,just didn't notice it.
Paisano
Old 08-04-2010, 01:54 PM
Even on the upper advance shaft where the reluctor sits?
Old 08-12-2010, 09:10 AM
Paisano
Wiki Edits: 4
Sorry that It took me so long to get back to ya.Even when you install the distributor you'll notice that the oil pump shaft takes away just about all the slack in the distributor shaft.Try it and see.
Paisano
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
