ford duratec - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2006, 06:42 PM
ford duratec
i once found a website that had conversions for turning a duratec v6 for rear wheel drive. now i cant find it any help would be great thanks
Old 08-05-2006, 02:01 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
What vehicle are you working on?
There are factory duratec rwds out there -- Lincoln LS....
Old 08-05-2006, 02:03 PM
i have access to a 2.5 out of a contour and waswondering if a rwd conversion was possible, if it is i would get the car to use the motor and computer for a future project
Old 08-05-2006, 02:29 PM
pmeisel's Avatar
It's possible. You will have to change the motor mounts (iirc they are oddball on the 2.5L contour) and may have to change the flywheel or flexplate to match the tranny you choose, but that is most of the difference. The RWD and FWD duratecs are virtually identical except for component that are unique for either calibration or vehicle packaging, neither of which are a major concern for you.
Depending on what you put it in, you may want to change the oil pan. Also iirc the water pump drive is different on the fwd and rwd applications, you may want to go to an electric water pump to make that issue go away, or else pick up the accesory drive parts and pump from a rwd duratec.
I don't have any of the hardware in front of me anymore and am working from memory, but I think this would be a relatively simple thing to do. And it's a light engine, it would be nice in a light vehicle like a track T or a smaller coupe or roadster.
Old 08-05-2006, 02:38 PM
so the motor will bolt up to any new ford rwd auto? also what besides the LS had duratec rwd? thanks
Old 08-05-2006, 03:22 PM
pmeisel's Avatar
Not any auto -- i'd have to check but I think the R55 tranny fits it. Some of the baby Jags ran the Duratec as well. one is fwd the other rwd.... and we sold some duratecs to Mazda, I forget which vehicle they put that in.....
Old 08-05-2006, 04:02 PM
thanks for the help if you do find out let me know
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 07:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 04:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
