Ford engine block codes, casting numbers, and specifications - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 01-31-2011, 06:26 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
From the Hotrodders Knowledge Base, here are 80 different sites listing engine block codes, serial numbers, casting numbers, and specifications for Ford engines and engine parts:
You can add any new ones to the list via the "Add a new link to this category" link at the bottom of the page.
Quick reply to this message
Closed Thread
casting numbers on engine block lndtrent@att.net Hotrodding Basics 7 09-10-2011 04:49 PM
Ford V8 block casting numbers whitecloud Engine 4 11-12-2009 08:45 AM
Ford Engine Block Casting Numbers Spiritof1806 Engine 2 10-19-2006 05:56 PM
quadrajet casting numbers and codes ryan chacula Engine 2 10-23-2005 10:27 PM
