Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford Engine Choices
  #18 (permalink)
Old 01-02-2013, 10:08 PM
junker junker is offline
Ford Engine Choices
Back again. A Galaxie a uni-body? Are you serious? And a 4-speed? A junker big spline 4-speed will run at least 2K probably more. You will need one from a big car, Torino and Mustang are different. Figure at least another 1K to rebuild it, unless it's broke then it could easily double. And the rest of the setup will have to be pieced together. Figure another 2K or more before you have all the parts. A new shifter alone will cost close to 1K. Use a C6 or even an FMX, you should find one cheap, and get it rebuilt for under 1K. Lots of Ks here, but you get the picture, Fords don't come as cheap, or plentiful as Chevs.
