My apologies in advance if I may have missed it ... but what engine / trans was in the car originally?
The 240 (6 cyl) and 289 (V8) mave have had similar mounting systems (engine and frame mounts) and bell-housings, but the FE engines used different mounts, radiators, and bell-housings for sure ... quite possibly even different transmissions and driveshaft lengths. Radiators had hose connections at opposite sides on the 289 vs the FE. FE Motor Mount 289 (and 240?) mountAutomatic Transmissions: It looks like C4 or FMX for the 240/289 and C6 or FMX for the FE engines. Not that swapping all of the above is not possible ... just that the OP might want to know this going in. |
Ford Engine Choices
Back again. A Galaxie a uni-body? Are you serious? And a 4-speed? A junker big spline 4-speed will run at least 2K probably more. You will need one from a big car, Torino and Mustang are different. Figure at least another 1K to rebuild it, unless it's broke then it could easily double. And the rest of the setup will have to be pieced together. Figure another 2K or more before you have all the parts. A new shifter alone will cost close to 1K. Use a C6 or even an FMX, you should find one cheap, and get it rebuilt for under 1K. Lots of Ks here, but you get the picture, Fords don't come as cheap, or plentiful as Chevs.
The 352 I had in a 65 Merc would have best utilized at the end of a chain and thrown overboard. It was just a gas-guzzling gutless PIG of a mill. I had 2 390's ... which weren't TOO bad, considering I drove the ever living out of them, and they weren't built for higher RPM ... pretty much wrung them out in about 20,000 miles. I put an Autolite 4-barrel carb and intake on the 67 Merc and got decent power out of it. |
ANY engine can be made to perform. How much do you want to spend? I think the original question was about fixing up a car without breaking the bank. Put together the total price of a 385 engine conversion with 4-speed, rebuilding the engine and transmission, putting together a stick setup, and don't forget the custom exhaust system too then repost. 90 pounds more? Yeah maybe each head.
Ya know troll, that's the same as calling me a liar and I don't like it much. I do my best to post genuine facts on this site. If you have some evidence that there is more than a 95 lb difference between an FE and a Lima, post your evidence. Otherwise, get the hell back under the bridge and shut up.
Ya know, worm, I don't think I like you too much either. Facts is way different than heresay. You lost me when you said FE engines were junk. More facts? Get real bozo.
Techinspector is correct.
A 390 weighs in at 650 and 460 weighs in at 720 ish. That is under 90 Lbs. Difference. Techinspector is no Bozo, he knows his specs. Why...well that is because it is what he does. ![]() Now , that being said what is it that you do? So far All i see is someone who rudely disrupts an otherwise decent conversation, with a new, member about a possible build for a classic ride , complete with actual fact from well known and very reliable sources here. ![]() Not real impressed with your activity here so far. ![]() FE engines are not much more impressive. Dont get froggy here, I am not amused. Grow up and bring some facts , not smack talk. Consider yourself served
Fact is stranger than Fiction |
| The Following 2 Users Say Thank You to LATECH For This Useful Post: | ||
66GMC (01-03-2013), 69 widetrack (01-03-2013) | ||
Only saw 3 428 engines available nationwide. 2 in California and one in Minnesota.
1 427 available in California
I wouldn't second guess, techinspector1, he is one man on this forum that has consistently given good, valid and concise information. If you have facts that are different junker, show us your sources.
Ray |
engine choice
351w stroked to 408 nothin but serious money with the fe's 500 hp/500ft torque with a mild build. dress the top to look the same, dart blocked W stroked to 427, cobra top. plenty of room in the bay. check the # whats original if thats the way you want to go no 352, 360 390 money cant fix those. 460 I always did like those. drop them in early bronco's for mud slingers.
fes
have had a 390 in 1967 galaxey,inst a reground cam and it was verry good,had over 100,000 miles with no isues. even a early 360(edsel version) with early 352 heads (machined combustion chambers and solid lifters) it was faster than my pals 348 and my car was 62 merk rag. most of my buds had chevys,most of our weekends wher changing cams and transmitions. so for me not a lot wrong with fes and reserch will give 1 som cheap options to improve them. the 1s to stay away from 360 truck,no compesion poor heads and bad exhaust |
@66GMC - I actually do not have the car yet. However most of the 67 Galaxies I have been looking at either have the 289 or the 390 in them. I would like something a little bigger than the 390. So I was asking what would be a good swap , that isnt too expensive , reliable and not too hard to work on. I know there are a lot of choices , just wanted to see what the best options were. If I have to change the tranny thats ok.
Also I am not worried about fuel economy or it being an original Galaxie engine. There are some good options that Galaxie had that year , but they tend to be on the expensive side , like the 427 for instance. Also , it needs to be carburated. I do not know enough about fuel injection to mess with one. Thank again everyone. |
stroke the 390 if you want a decent FE.they need better heads thats all.My friends 427 makes very good power.he did spend some money on the heads(actually the engine was expensive because its a ford)and its a side oiler
| Tags |
| 427, 428, ford, ford engine, ford motor company |
| Engine choices | rakrick | Engine | 2 | 12-30-2010 02:17 PM |
| Crate Engine Choices | SmokeShow01 | Introduce Yourself | 2 | 05-10-2009 10:51 AM |
| Engine Choices | projectjohn | Engine | 18 | 09-20-2005 05:20 AM |
| head, componant choices. ford 302 | Jared | Engine | 2 | 03-01-2004 12:07 PM |
| Outlaw 4 Cylinder Engine Choices | KSGerry | Engine | 13 | 06-14-2003 08:33 AM |
