Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford Expedition Brakes
  #31 (permalink)
Old 03-04-2012, 04:48 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by Augusto
went to this hill yesterday and coming downhill I made several panic stops, the first one it slow down fairly well but took too long to stop, made a second one and it took soooo long, sure crash would of be if it was a real panic brake, third one I had to use both feet and almost bent the steering wheel, it took even longer to stop, carefully went back to the shop that's about half mile down the road and measured the temperature of the discs, pads and calipers, an average reading was 310 deg farenheit for the rear brakes and 290 deg for the fronts, this means that the pads are being applied and the bias is right, but maybe not enough clamping force? what would be a temperature reading after three very hard brakings?
nobody has ever measured the brakes temperatures?
