Ford Expedition - Pulling axels - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2006, 07:44 PM
trident's Avatar
I have a 2002 Ford Expedition 3L55 rear end. I want to pull the axels to have them redrilled for a Chevy wheel (going on my '53 Chevy sedan). Can't figure out how to do it. I've unbolted (four bolts) that hold on the dust cover and bracket for the brakes. From here I'm not sure what to do. I've taken off the rear end cover and then what?
Old 04-27-2006, 08:15 PM
302 Z28's Avatar
Not really familiar with the Expedition, been away from the Fords for too long. I will assume it's a Spicer type rear axle since you said you pulled the cover off.
There are four gears inside the case that the big ring gear is bolted to. Two of those gears are on the axle ends and two are on a shaft that goes through the case that the ring gear is bolted to. That shaft should be held in place with a screw. Rotate the rear axle until that screw is visible and remove it. Slide the shaft all the way out. Once the shaft is out push in on both axles. On the ends of the axles there should be some "C" clips. Remove the "C" clips and slide the axles out.
Now if you have a traction loc that is a different animal.
Vince
Old 04-28-2006, 08:36 AM
trident's Avatar
The way you describe it is how it looks. I saw that screw and wondered if that was what I needed to do. I did not see the C clips, but maybe they will be easyer to see once I remove the center pin. Will try to di it tonight after work. Thanks!
Old 04-28-2006, 08:50 PM
302 Z28's Avatar
The C clips are on the end of the axle and fit in a depressed area of the axle gear. Once you remove the cross shaft and push in the axle the C clip should fall out.
Vince
Old 04-29-2006, 01:34 PM
trident's Avatar
That was it. They are out now so I can get them redrilled for the Chevy wheels. Any type of adjustments needed when they go back in or just reverse the process?
Old 04-30-2006, 03:34 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
You just reverse the process of removal to reinstall them.
Old 05-16-2006, 06:51 PM
trident's Avatar
ya I'm screwed now
Pulled this post back up for an update. I got the axles back today. Drilled for my Chevy '53 wheels. Slid the axles back in and thought I'd see how the wheels fit. Over the new bolts no problem, but the center of the wheel is to small for the center hub of the axle. Yes- I know what that makes me, but what can I do from here? Did this happen because the Expedition is a larger size than the Explorer rear? Do I have to use a ford wheel or would a new Chevy Wheel fit? The wheel bolt pattern is 4 1/4 to fit the old wheels. Can a new wheel be purchased with a 4 1/4 5 lug pattern? Can I still match up the wheels if I use a Mustang II front end? Makes me sick, know what I mean?
Old 05-16-2006, 07:43 PM
trident's Avatar
Now that I've cooled down a little, I figure the best way out of this is to put the bolt pattern back the way it is and match the front to the rear, ie, use Ford wheels. Only question I have deals with the center hub, is it a bigger diameter on the Expediton than what I can order on a Mustang II front end? Wost thing is I really wanted to use the old wheels and I've burned $100.00.
Old 05-16-2006, 07:58 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
Ford expedition axles
This may be a dumb question,but did you check the width on that rear end,compared to your chevy? I think the expedition rear is wider then the explorer,and it could be too wide for you. I have turned down the center of axles to fit different wheels,just leave enough to keep the drum(or rotor) centered,and turn down the outer part to fit your wheels.
Old 05-16-2006, 09:33 PM
trident's Avatar
I did check the width and it is with in a 1/4 inch best I can tell. Never checked an Explorer, was told they would work as well, but I don't know how close they compare (should say I don't remember because I think it has been discussed in here somewhere before). I called a friend tonight who gave me a name of a machine shop that will look at the axles for me to see about turning them.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 07:00 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 01:37 PM
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 07:10 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
