ford explorer A4ld tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2009, 03:36 PM
mattmar's Avatar
Hi guys! i am hoping someone can help me out on this one. I have a 1992 ford explorer with the A4ld tranny in it. the problem i am having is that when it is cold it will not shift. i can manualy shift from 1st to 2nd just fine but when i go to drive the motor just revs. if i just put it in drive it never gets out of 1st gear unless shifted manualy . Now here is the strange part! after about 5 miles of driving in 2nd gear i can put it in D and it drives like a brand new truck. any help is greatly appreciated. Thank you.
Old 10-21-2009, 07:56 PM
Wiki Edits: 31
It needs a rebuild bottom line. shifting from 1 to 2 and then to D when it allows makes it run on the bands, kind of a crutch on the trans.. A4LD's are known for problems and generally last 130k miles
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Attaching my Tranny Problems ryanf Transmission - Rearend 1 06-15-2004 02:00 PM
350 Turbo Tranny Problems Dans83Olds Transmission - Rearend 4 08-06-2003 01:59 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
70's Era Ford F150 Explorer paint HELP!! godofgsxr Body - Exterior 5 12-23-2002 05:00 AM
