Ford F 150 ac trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 04:04 PM
On my 1993 Ford pu the air and heat both run until I unplug the wire that goes to a switch on the ac unit under the hood when its unpluged I have heat but when it is put back the ac comes on what can cause this to happen ?
Thanks
Old 04-25-2012, 05:29 PM
LATECH's Avatar
The A/C compressor should run when defrost is turned on. It should not run in any other setting (except A/C of course) if it does it could be a wire that has been jumpered somewhere, or the panel switch is shorted.
ford f-150 4.9 Jay Smith Engine 11 04-16-2011 08:57 PM
1948 ford f-1, 1981 ford f-150, mustang ll pile up derrick_500 Suspension - Brakes - Steering 6 09-09-2008 01:17 AM
1998 Ford F-150/1957 Ford Delivery Sedan Dennis Anderson Introduce Yourself 1 12-29-2006 06:10 PM
1989 Ford F-150 Cruiseomatic General Rodding Tech 9 11-20-2003 07:22 PM
1989 Ford F-150 Clinton Hotrodders' Lounge 0 07-09-2002 02:55 PM
